-   Powerquest (https://www.offshoreonly.com/forums/powerquest-49/)
-   -   prop change (https://www.offshoreonly.com/forums/powerquest/32254-prop-change.html)
wes29 09-03-2002 05:44 PM
prop change
I have a '94 290 Enticer w/ Twin 502's. I've had the boat for about a year now, and it has 23" mirage props. The boat runs top end at 76 mph on gps. If anyone knows what a better prop set up would be, I would greatly appreciate some ideas. I would love to be able to get closer to the 80 mph. mark! Thanks!
Tinkerer 09-03-2002 07:17 PM
What rpm are you running at WOT??? If you are close to the Wot rating of your engine you could try running labbed 25 mirage props. Don't go to 4 blade props unless you are having planing or handling problems. With the labbed 25's I would think you should be close to 80 MPH. If you are running under the WOT rating by 200-300 rpm just lab the 23 and you should gain 300 rpm and about 3 mph.
GOOD LUCK
wes29 09-05-2002 05:48 AM
GOOD LUCK
Thanks for the info! I do run at 4600 rpm. wot. so I will have to try a set of 25" labbed props.
Kentz 09-05-2002 07:24 AM
@ 4600 WOT, you'd be better off labbing your 23's
Tinkerer 09-05-2002 10:00 PM
I agree You want those engines up around 5000 to 5100 rpm.
Lab the 23,s and you should be at 4900 to 5000 rpm and gain 3 mph.
