-   Powerquest (https://www.offshoreonly.com/forums/powerquest-49/)
-   -   Here we go again............... (https://www.offshoreonly.com/forums/powerquest/50106-here-we-go-again.html)
Kentz 05-15-2003 05:36 PM
Recall - Today's mail
"It is necessary to inspect your water rail at two locations for possible corrosion. At this time we will also replace a fitting and a connector on each water rail. Failure to do this could cause water to collect in the bilge." Bulletin 2002-04
No mention of serial #'s, mine are #61302/61305
I hope its just the salt water/dissimilar metal thing...........
Raypanic 05-15-2003 07:09 PM
496's? It's great they let you know at the beginning of the season rather than in the winter!
Macklin 05-16-2003 06:31 AM
Maybe BillR saved the serial numbers. If not, you could do a search in the General Board for a post about this last winter. (name of post something like....496 Recall) The serial numbers were listed there. I know our motors are later models and are not included in the recall.
Get it fixed! BillR was on board a 26 Donzi that had one cut loose. Not a pretty sight to see the cockpit start to fill with water.
BillR 05-16-2003 06:38 AM
I had the serial #'s somewhere. I know that mine were about 80 to 90 away from the recalled units.
Do get that fixed. It can/has broken loose while underway and the seawater pump was filling the boat full of water FAST.
