Sea strainers
Hi guys,
Need to know if any of the 340vyper owners have strainers installed in their boat and where in the motor compartment you installed them. I want to purchase a set of REX marine strainers for installation in the spring and need to know the best location and any fittings you used to complete this. Thanks for your help Jeff |
BillR is the guy to talk to. I believe he had his installed by PQ so that should give you a good idea on where they put them.
PQ installes them on the "firewall" under each inboard trim pump. Not sure what you need for fittings, other than more hose. Here is a pic on mine on the port side. The strainer is a Gaffrig (Livorsi) and has a anodized red top.
And here is a pic of the starboard side. The strainer is harder to see in this pic.
Hey Bill, can you repost the photos if you still have them?
2 Attachment(s)
Here are mine on the 380...
Originally Posted by Need4SpeedGTCS
(Post 3721107)
The bilge pump is further back, you can just see the float switch under the port side strainer.
Apparently the strainers were mounted up on the bulkhead but the previous owner moved them down low to where they are now...I vaguely recall he had some sort of water flow issue. |
Get a hold of bsc on here. He'll get you a pic of them installed on his 34...
Dave |
| All times are GMT -5. The time now is 07:04 AM. |
