30 Sutphen Prop Help >
Old 04-14-2005 | 10:06 AM
Leathl_WS6's Avatar
Default 30 Sutphen Prop Help
Ok I can't give much rpm or speed info yet. I have only had the boat out 1 time and only up to 4k, at 4k it was around 50mph. I had plenty of throttle left.
I'm just looking for a good starting point. I Have a set of 25 mirages on it now. The boat ia a 1981 30ft sutphen. Motors are 502's and make in the low 500hp range. Drives are TRS.
Do you think 25's are close? Should I be running a 4 blade? The boat had 22 Bravo ones on it. Can these be repitched bigger to better fit my application?
Thanks Rob
Leathl_WS6 is offline
Old 04-14-2005 | 10:35 AM
throttleup's Avatar
Default Re: 30 Sutphen Prop Help
Are they Mirages or are they the Mirage Plus?
The props you have now are a good starting point get some time on the boat and get a feel for what the boat is doing. Then with that information you can decide what you want from the boat. Do you want to get on plane better, do you want more top end, more cruise speed, better handling, etc.
Whats the target wide open throtte rpm. That will have an effect on what pitch prop is right for you.
The 22 Bravo 1's can be up-pitched about an inch, if they need to be.
Matt
throttleup is offline
Old 04-14-2005 | 12:11 PM
Leathl_WS6's Avatar
Originally Posted by sutphen30
i'll get you the props that were on my boat,out to you.damn tax season.sorry about that.
bill
Not a problem. I apperciate it. Just looking for more information as well.
Old 04-14-2005 | 12:43 PM
I have Mirage plus 4 blade 26's... Scott & Ruben both were suprised at the size of the prop on my 30' but wow what a midrange... little slow out of the hole.
I have 420's & TRS
SinkorSwim is offline
Old 04-14-2005 | 02:04 PM
Leathl_WS6's Avatar
Matt
They are just the mirage not the plus. Ultimitatly I am looking for a good cruise speed. I would like to be able to cruise at 50. Target WOT is 5400 to 5600.
Old 04-14-2005 | 02:06 PM
Leathl_WS6's Avatar
I have 420's & TRS
Mirage makes a 4 blade? I Never seen or heard of such a thing.
Old 04-14-2005 | 03:53 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: 30 Sutphen Prop Help
Mirage and Mirage Plus only comes in a 3BL configuration. The Bravo 1 would be the 4 BL comparison for the Mercury line.
Brett Anderson
bbladesprops is offline
Sydwayz
Sutphen
0
04-16-2008 11:25 AM
LEOPAJM
Sutphen
32
02-26-2008 06:12 AM
Jeff D
Prop Talk
1
07-12-2005 05:58 PM
BODYSHOT1
04-12-2005 08:25 AM
marinetrans
11
02-19-2004 09:02 PM
