hydromotive props >
hydromotive props
hydromotive props
Old 05-16-2005 | 07:08 PM
briana's Avatar
hydromotive props
Anyone intrested in my hydromotive 26 rh and lh propellers, Iam taking them off my 32 fountain as Iam installing prochargers and need to turn bigger blades, switching to 30 bravo1's.
briana is offline
Old 05-16-2005 | 07:33 PM
Ran-Dom 32's Avatar
Default Re: hydromotive props
I may be interested - how much you want for them? are they stock untouched? what speeds were you seeing before & after the prochargers?
Ran-Dom 32 is offline
Old 05-17-2005 | 07:14 AM
briana's Avatar
$500 for both, they are untouched by myself, I have had boat for 4 months and Iam the second owner. asked previous owner and said untouched also
specs
current
502's (stock) running 77 mph(gps) @5000rpm
drives turning in and toed in 1/4 in
hopeful specs with lavorsi prochargers, intercoolers
620hp spinning 30p bravo1
upgraded xr gears, fresh top ends and stock exhaust
90-92mph is the target #'S
briana is offline
Old 05-24-2005 | 01:50 AM
Will they fit the bigger XR shaft?
Back4More is offline
Old 05-24-2005 | 06:19 AM
briana's Avatar
not sure, they are off of bravo 1 drives. I will find out and post findings soon.
briana is offline
Old 05-24-2005 | 07:03 AM
throttleup's Avatar
If the props are more than 18 months old then they have a standard shaft hub welded in. They would have to have the standard shaft hub machined out and an XR hub welded in. This is a common modification to these props. The new stock of Hydromotive props use a square bore which will accommodate any of the Mercury square hubs, including the XR hub.
Matt
throttleup is offline
Old 06-02-2005 | 12:48 PM
WheelerDealer's Avatar
Registered User
Are the props still for sale? If so, how can i contact you?
here is my EMail[email protected]
WheelerDealer is offline
Old 06-05-2005 | 08:08 AM
briana's Avatar
Yes they still are for sale email me a [email protected]
briana is offline
GO4BROKE
Sonic
9
08-27-2007 07:22 AM
mcrsr
Prop Talk
5
05-11-2006 05:29 AM
MnFastBoat
6
07-24-2005 09:22 PM
lucky strike
08-27-2004 06:13 PM
RUSSSR1
08-09-2002 09:39 AM
