Metal erosion >
Metal erosion
Metal erosion
Old 06-09-2005 | 07:38 PM
Ms PatriYacht's Avatar
Default Re: Metal erosion
Here are the pics.
Ms PatriYacht is offline
Old 06-10-2005 | 08:12 AM
throttleup's Avatar
Can you email the photo to me I cannot quite tell from the photo you have posted. Is it pitting or does it appear to just be on the surface?
Julie
throttleup is offline
Old 06-10-2005 | 08:47 AM
PatriYacht's Avatar
It is several thousanth's deep. Lines are forming and they are getting longer and deeper. I'll try to get Donna to e-mail them. I'm at work and they are on home puter. Thanks.
Old 06-10-2005 | 08:58 AM
I just them to you Juile
Old 06-10-2005 | 09:00 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Metal erosion
This does not appear to be cavitation burn.
First, it is on the low pressure side of the blade. Cav. burn happens on the face or high pressure side of the blade.
It looks to be build up rather than pitting. Lake Erie has the water make up to causes this type of mineral build up on propellers all the time.
[email protected]
bbladesprops is offline
Old 06-10-2005 | 09:09 AM
PatriYacht's Avatar
If it is a mineral buil-up, it is very metallic looking. I tried to sand it smooth once with 280 grit wet sandpaper. Didn't work. Too hard. And it is only this prop. The port prop is still shiny. Not arguing just trying to give as much info as possible. Thanks.
Old 06-10-2005 | 09:18 AM
Outdrive1's Avatar
Masher touches my
If its just build up on the prop try Lime Away. Dont sand your prop what ever you do. Hard water stains will come right off with non abrasive Lime Away. Dont sand it, steel wool it, scrub with a scouring pad, anything abrasive will ruin the finish.
Outdrive1 is offline
Old 06-10-2005 | 09:51 AM
PatriYacht's Avatar
I used acid based mag wheel cleener on the prop before taking the picture, just to clean it up. No sign of calcium. Steel wool won't touch this.
MitchStellin
12-13-2004 09:33 AM
JUSTONCE
19
05-04-2003 05:42 PM
BETTERTON
4
07-29-2002 06:06 PM
