Formula 357...26% slip with mirage 23's >
Old 06-29-2005 | 08:27 AM
Default Re: Formula 357...26% slip with mirage 23's
Poorsche Did you ever think that the new 454's are only 300hp. That mite be the problem. If the boat ran good with the 370's your new motors mite be the problem. Put up some motor specs, 454's can make hp anywhere from 300 to 650hp with a single carb pump gas and no supercharger.
z.zuperboat is offline
Old 06-29-2005 | 06:23 PM
Poorsche's Avatar
Thanks for this reply too--I really appreciate it.
I did the unthinkable--I read the manual--looks like its 330HP per MarinePower with optimum WOT of 4800 RPM. I'm only turning 400-4110 at WOT. I even checked this weekend to see if the throttle cable was pushing the thing wide open--it is.
I've changed the drives--still TRS but I think they are deeper in the water han the originals. THe prop shaft is 9" below bottom at drive--drives are 33 1/2 apart on center.
Poorsche is offline
Old 07-03-2005 | 10:55 AM
lakepop
Originally Posted by offshoreratboy
Hey lakepop...What kind of power do you have. Mine are fresh 420's with some updates with the help of Dennis Moore. He designed the engines and I built them. He claims they will make 500hp. I'm not sure I'm there yet but they are more powerfull than the 420's were. I am still contemplating some carb changes, and I have a set of Vortech superchargers ready to go on this fall.
Power is stock 502 mag's 450 hours
lakepop is offline
spazboz
05-28-2019 07:08 AM
nmogren
01-22-2008 10:13 AM
bford1
12-22-2005 11:16 AM
formula271
06-15-2005 09:38 PM
RNH
07-14-2003 12:39 PM
