can 496 ho be run with bad resonator >
Old 06-27-2005 | 08:02 AM
Default can 496 ho be run with bad resonator
it sounds like an exhaust leak but everything is tight and i can't find a leak. i suspect that a resonatoris bad. can i use the boat 1 more time before replacing?
89scarab3 is offline
Old 07-02-2005 | 04:48 PM
Cool Re: can 496 ho be run with bad resonator
Its very easy to remove the riser on a 496. If you are getting a rattle or vibration from one exhaust I would open it up a check things out. the problem could cause more damage that could risk the risers integrity as far a sealing from cooling raw water, and a leak there would be casistrohic. If its just a broken out internal flapper thats not as serious and could be run that way for a long time without damage. If Things are breaking up in the riser find out now not later. Just my thoughts.
Ray @ Raylar
Raylar is offline
parkster747
Do It Yourself, Boating on a Budget
3
01-05-2009 01:32 PM
Waterfoul
04-21-2005 07:47 PM
Panther
06-13-2003 06:25 PM
Mr. Demeanor
05-28-2003 06:30 AM
