4 Blade or 5 Blade prop? >
Old 10-18-2005 | 01:51 PM
Default 4 Blade or 5 Blade prop?
Can someone please tell me the difference between a 4blade and 5blade prop? Other than one has more or less blades than the other. Thanks a mill!!
CA_Southpaw is offline
Old 10-18-2005 | 02:20 PM
throttleup's Avatar
Default Re: 4 Blade or 5 Blade prop?
The differences are really in the perfromance changes due to the additional blade. Each time you add a blade you will experience, improved hole shot, increased acceleration & increased cruise speeds. Additionally, each time a blade is added the stern lift is increased . There are alot of variables that must be considered before you can determine the overall benefits of the different propellers, on different boats.
Julie
throttleup is offline
Old 10-19-2005 | 10:27 AM
lucky strike's Avatar
Does a 5 blade put more stress on a XR drive ?
Does a 34" pitch put more stress than a 32" pitch ?
If so why ?
lucky strike is offline
Old 10-19-2005 | 10:44 AM
el indio's Avatar
Less slip would be my guess..............more load.............
el indio is offline
Old 10-19-2005 | 12:56 PM
iamfaster's Avatar
in theory???.....will the extra blade create a more balanced prop, thus, less "slap" through water at higher drive heights....less stress on drive?????
iamfaster is offline
Old 10-19-2005 | 03:42 PM
throttleup's Avatar
The additional blade(s) definitely creates a more balanced prop. With a noticeable difference between a four and five blade. There is a noticeable difference between a 5 and 6 blade as well. There is less vibration with more blades, especially at higher drive heights.
I also believe there is less stress on the drive with more blades, the vibration you feel from the prop is coming through the drive. The exception being when the boat is launched. When the boat lands a 5 or 6 blade is going to hook up harder and will load the drive up more than a 4 blade will.
Old 10-19-2005 | 05:48 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: 4 Blade or 5 Blade prop?
This could become a book.
We find the biggest differences from 3-4 and 4-5 blade props because of the distance between load and un load is greater than 5-6.
Planing and cruise speeds almost always improve going from 3-4 and 4-5 blades. BUT, not always. 5-6 can improve this also but not as drastic as the others.
"Certain" hulls respond better to more blades. Even the ones that don't like more blades, most likely will improve on the low end to a certain point and then can't handle the additional stern lift. (I see we now agree, more blades, more stern lift.)
More blades less vibration. More blades better hook up which means higher loads on drive components. However, with the correct hp/wt/drive combo it saves drives because of the smoothness. On the other hand, "high" hp with such hook up can be detrimental to a Bravo, Alpha or comparable drive.
One other important thought.................more metal in the water is additional drag. What does this mean?????????
What wins, less slip or more drag? Hummmmmmmm.
[email protected]
bbladesprops is offline
Old 10-20-2005 | 02:55 PM
The amount of blades on a prop also depands on de pitch ratio and the revs it is running at. The higher the pitch ratio the more blades you should have to prevent very high pitch ratio per blade, this improves efficiency. A slow reving prop with high speeds requires a lot of pitch and also a high amount of blades. (class 1 Cats) Fast turning props require less pitch and therefor less blades (F1 outboard motors, Hydro planes).
Mono Powerboater is offline
Old 10-22-2005 | 07:19 AM
throttleup's Avatar
The saying that more blades are slower does not necessarily apply to todays high performance boats.
What is commonly misunderstood is that more blades does not necessarily mean there is more prop, or metal, in the water. With some of the new hull designs we are able to raise the drive higher than with older hull designs. By raising the drive there is less drag from the lower unit, but it usually requires more blades to make up for the loss of metal in the water caused by the higher drive height. So in the end there is the same amount of blade area in the water as there was before with a deeper drive with fewer blades.
This can only be done with hulls that will naturally carry the bow without the propeller or drive pushing the bow up. That is another reason why you will find most of the high performance boats with props that have a lower rake angle than in the past. These hulls do not need the bow to be carried by the props.
All of this dial in is done on a case by case basis. The down side is when you have a high performance boat that is dialed in just right it will also be very sensitive to weight and set up changes. in short a boat that is very dialed in with a high drive height, 6 blade props, cg just right, etc may not be the best set up for your needs.
Matt
fandango
Wanted
6
05-15-2008 07:14 PM
Inspector
Prop Talk
1
07-09-2007 07:50 AM
Rebel_Heart
Prop Talk
16
03-23-2006 01:29 PM
CA_Southpaw
American Offshore
13
11-06-2005 07:18 PM
NetGain
19
06-29-2004 08:32 PM
