Need some prop suggestions for a 28 Powerplay >
Old 11-02-2005 | 06:45 PM
Default Need some prop suggestions for a 28 Powerplay
I just purchased a pair of Mariner 300's with 25" midsections for my Powerplay 28'. Where do you think I should begin with prop selection? The lower units are fleetmasters. Thanks.
cowisl is offline
Old 11-03-2005 | 03:35 PM
Default Re: Need some prop suggestions for a 28 Powerplay
Any ideas? Boat is now rigged.
cowisl is offline
Old 11-04-2005 | 07:54 AM
throttleup's Avatar
This is a loaded question. Without seeing the exact set up and taking measurements it is hard to determine the pitch you will need. Additionally,
test props for outboards are very difficult to find. We will need some baseline numbers to get started. Do you have any props with the boat or laying around that you can try to begin baselining?
Julie
throttleup is offline
Old 11-05-2005 | 01:33 PM
We have some old three blade chopper props that were previously on the boat with the 2.5's, but I dont think they will be anywhere near what we want.
cowisl is offline
Old 11-05-2005 | 01:34 PM
Will try to test by the end of next week.
cowisl is offline
Old 11-07-2005 | 05:28 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Need some prop suggestions for a 28 Powerplay
There are options depending on the desired results. What pitch are the choppers? They most likely will be too small since the power bands are at such different rpm ranges between the engines. The 300's typically ran large pitch with a 6420 rpm limiter while the 2.5's run small pitch to run mid 7's.
Let us know how it goes. We may have something for you to try.
[email protected]
bbladesprops is offline
Old 11-27-2005 | 03:15 PM
The rev limiter on these motors is 6200. Our mechanic says we should try 14 1/2x32s. Anyone have anything like this to try? Thanks for the help.
cowisl is offline
razor1115
Prop Talk
5
08-04-2008 01:58 PM
35 White Lightning
Prop Talk
7
06-07-2005 11:38 PM
dtsquest
Powerquest
4
03-10-2005 06:46 AM
Formula78
7
03-20-2004 03:55 AM
NEVRENUFF
10
07-09-2002 01:50 PM
