Prop Slip factor >
Prop Slip factor
Prop Slip factor
Old 12-02-2005 | 04:17 PM
superboat1989's Avatar
Default Prop Slip factor
What is the expected prop slip factor for a 4 blade merc Trophy plus 12-15 %?
superboat1989 is offline
Old 12-02-2005 | 04:43 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Default Re: Prop Slip factor
It depends.
We did a 27 Trophy for a Stroker Bass boat / 225 ProMax last summer that ran 5% slip. (1.87g.r., 6700 rpm, 87mph)
Other applications will run in the numbers you mentioned. Depends on hp/wt ratio, hull design and a bunch of other stuff. If your in the 12% range with most boats, your doing well.
[email protected]
bbladesprops is offline
Old 12-03-2005 | 09:47 AM
224
mharrison is offline
Old 12-04-2005 | 10:56 AM
throttleup's Avatar
We need more information;
What boat are you going to put the Trophy on?
What kind of power?
Matt
throttleup is offline
Old 12-07-2005 | 09:35 AM
I currently have a 23 P trophy plus on 24 ft Superboat with 250 EFI. runing 6000 RPM at 66-67 MPH. I do not know the history of the prop but it was modified.
Slip appears to be very low for the speed/RPM I am running. %?
Old 12-08-2005 | 12:45 PM
Smile Re: Prop Slip factor
11% is pretty good. I'd say, if the low end and mid are as good, your there.
[email protected]
Old 12-11-2005 | 07:29 PM
anytime you run a trophy prop you have to add 1 in of pitch to figure out your slip .a trophy is a progressive pitch prop. a good slip factor is about 10%.
jerrys dog is offline
Old 12-12-2005 | 05:39 PM
jerry is correct in that the Trophy propeller is progressively pitched. This means the leading edge is at a lower pitch than the trailing edge. The overall pitch still remains as stamped. Therefore it really isn't necessary to add 1" of pitch. The old procedure was to add an inch of pitch if the prop is cupped. Most all props are cupped today. As well, most props are progressively pitched.
[email protected]
Old 12-13-2005 | 07:32 AM
I need to check the low and mid range numbers. Thanks you for the info you have all provided!
If I send in the prop can you determine whats been modified from stock Configuration?
Old 12-13-2005 | 09:44 AM
The hot prop for a 24 super with a single 200 is a trophy ?
z.zuperboat is offline
