47 lightning need to know prop and x dimension >
Old 02-08-2006 | 04:05 PM
Default 47 lightning need to know prop and x dimension
I'm in a project with a 47 need advice triple 525 gear ratio 1.5 want to use bravo 1 prop 4 blade anyone's that want to share some information and experience fountain didn't answer my mail
northpole is offline
Old 02-08-2006 | 04:52 PM
throttleup's Avatar
Default Re: 47 lightning need to know prop and x dimension
I would call a rigger or possibly Installer Marine, Bob. Someone who has set-up the 47's. As far as props go Hydro or Hering props would be great on the boat. I would run 5B or 6B props on her.
Julie
throttleup is offline
Old 02-08-2006 | 06:43 PM
Ted G's Avatar
My buddies 04 has 525s and ITS Bravos spinning Herring 6 blades I think they are 30 pitch. Boat runs right at 90 with moderate load.
www.cbpba.com
Ted G is offline
Old 02-09-2006 | 09:21 AM
throttleup's Avatar
Here is the number for Installer Marine. Bob should be able to assist you.
#216-402-5740.
Julie
Old 02-09-2006 | 10:48 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: 47 lightning need to know prop and x dimension
We have done numerous with Bravo 1 props and with Maximus 5 blades, also Herings.
What exactly are you asking? X dimension, pitch?
[email protected]
bbladesprops is offline
Old 02-12-2006 | 07:05 PM
Thanks for your replies i have been away some days now.I need to now x dimension for good all round performance and cruising speed and also recommended propellers and pitch
Old 02-13-2006 | 12:05 PM
For all around performance and good cruising, you can stay with the standard bravo drive cutouts. Fountain is pretty aggressive with their X dimensions anyway. You don't necessarily want shorty cases on this boat.
Using a set of Bravo 1 propellers in 28 or 30 inches of pitch will give you a good baseline and tell us which direction to go next. I think you will like those props but may opt to go to some 5 blades for better cruising speeds.
[email protected]
Old 02-13-2006 | 01:08 PM
My idea was to start with bravos 30???.The boat is a 98 mod that was delivered with Volvo's the fiberglass work is done and I'm ready to start cutting i just need to now where?????.
Old 02-13-2006 | 02:11 PM
Northpole, the x-dimension for your hull should be 17.25x19x17.25 . It looks like this gave the best results for your hull. Call if I can answer any other questions, 252-975-7048 (Chris). I'll be glad to research any questions that you have.
rackster is offline
Old 02-14-2006 | 06:25 AM
throttleup's Avatar
It's always better to mount your drives a little too high than a little too low. Spacers, if required, are a lot cheaper than shorter lower units.
Matt
