Damn boyz these are cheap >
Old 02-28-2006 | 08:52 AM
Dano's Avatar
Default Damn boyz these are cheap
One set w/hubs 32P Merc 4 blades maybe on the boat an hour $650 USD...
One set Lab finished 30P Merc 4 blades used sporadically for one season. Set up for T/S Cig $650 USD.
Dano is offline
Old 02-28-2006 | 11:49 AM
Sydwayz's Avatar
Forum Regulator
Default Re: Damn boyz these are cheap
Dano, are the 30P Flo-Torque hubs?
Are they thinned and sharp, or just trued, and still have some strength to them?
Sydwayz is offline
Old 02-28-2006 | 01:13 PM
Dano's Avatar
Sydwayz,
Sup dude, still running the AT? (Kind of shame what happened down at Sonic...hope they get it turned around.)
Oh yeah, to answer your questions...yup all the above plus some of the diffuser ring has been turned down. It was a $800 dollar lab job. The blades are definitely thinner but not paper. I ran them in the Ohio River so that should be testimony to the durability
Netted about 250 rpm on the gun. They come complete with the hubs. Maybe 25-30 hrs use. They have a little burring on the leading edges, but not really enough for a tune-up.
Not sure how they would work on a AT hull though
Dano is offline
Old 03-02-2006 | 08:45 AM
Dano's Avatar
Nobody needs a set of spares? WOW
Dano is offline
Old 03-02-2006 | 09:08 AM
Sydwayz's Avatar
Forum Regulator
Thanks Dano. I am working through a warranty/drive issue with the boat. I tried some custom Bravo1 27P 4 blades once, but they did not perform as well as the stock 28P B1s. As soon as the drive issue irons out, I will have this on the top of my list. I need another 250 rpm on the AT, but I would need to try the props first. I hope to be in the water in April.
Sydwayz is offline
Old 03-02-2006 | 01:34 PM
Dano's Avatar
Good luck with the drive issue. Been there, done that as well. April eh...69 deg today, 29 deg tomorrow....gotta' luv oHIya. I don't think these would work for you anyway, you'd be better getting your 28's done most likely.
Dano is offline
Old 03-07-2006 | 07:25 AM
Dano's Avatar
Guys these were brand new props purchased direct from Merc. Priced these puppies lately?
Dano is offline
Old 03-07-2006 | 03:31 PM
Dano, Give me a call re props. 716-628-6773. Thanks
hytech is offline
Old 03-08-2006 | 08:38 AM
Dano's Avatar
will do...3/8 am
Dano is offline
Old 03-11-2006 | 02:44 PM
Ran-Dom 32's Avatar
call me if you still have the 30's (check your PM)
Ran-Dom 32 is offline
