Cutting the Difesser Ring >
Old 03-12-2006 | 02:25 PM
375stinger's Avatar
Default Re: Cutting the Difesser Ring
...wats it look like? lol
375stinger is offline
Old 03-12-2006 | 02:42 PM
Harper220's Avatar
Originally Posted by US1 Fountain
Look at the prop on the end. Either you gots it or you don't.
That really tells him what to look for?
Harper220 is offline
Old 03-12-2006 | 02:51 PM
Harper220's Avatar
The diffuser ring is the part of the hub that flares out or a little lip. If it doesn't flare out and it's just straight then you don't have one. It runs the entire diameter of the hub or the center of the prop. Hope this helps.
Not the best pic but this Spinelli prop does have one. Most Bravos have them.
Old 03-12-2006 | 03:10 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
You're right. I just didn't have any pictures to show the difference.
Here's a link to Hydro website that shows the diffusiors, the bigger round items. The one on bottom shows a more flared look.
http://www.hydromotive.com/accessories.html
US1 Fountain is offline
Old 03-13-2006 | 12:06 PM
BajaRunner's Avatar
does it have any draw backs or should you always cut it to see some gain?
BajaRunner is offline
Old 03-13-2006 | 10:56 PM
how can i tell if i have one? we have hydromotive iv. thanks
You don't have diffuser rings on your Q Iv's in the pic.
Griff is offline
Old 03-14-2006 | 08:44 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Cutting the Difesser Ring
I believe there are a number of other threads prior to this one which go into this in detail. There have been some disagreements between some thought processes on this subject.
Our findings have been, remove the diffuser if blowout while planing is non existant. Difussers are more inportant with through prop exhaust. Risidual air can be drawn through the drive and cause some ventilation even with through transom exhaust.
Look at it this way, anything dragging through the water does just that, drag.
Strip, I think I remember you to have a high X and poor trim reaction. If the props are surfacing and a ramp on the props is induced, think of the result it creates.
It isn't for everyones application. Discuss it with your prop doctor before you cut it off at the local machinist or in your garage.
[email protected]
bbladesprops is offline
Old 03-14-2006 | 12:22 PM
Strip Poker 388's Avatar
Rob
I guess I should of search before asking I figure the ring is for plaining which I dont need and if its for exhaust I dont need that either.
It acted like the trim angle aroung 99 didnt make much diff ,between +1 to 2.50.
When I get the new drives and get a base line with the new motor and props ,then we will see what needs changing Its better just to throw mo power to it
Rob
Strip Poker 388 is offline
oldschoolfan
Detailing, Painting, & Fiberglass
4
02-10-2008 06:05 PM
CAPTAIN CHUCK
6
06-14-2007 03:14 PM
nocigarette
19
09-12-2006 09:05 PM
Cord
17
08-28-2003 12:26 PM
jafo272
08-19-2003 10:32 PM
