Cutting the Difesser Ring >
Old 03-10-2006 | 07:35 PM
Strip Poker 388's Avatar
Rob
Default Cutting the Diffuser Ring ?
Why? Please explain why and what it does . Say like on a 4 BL bravo one prop???
Rob
Strip Poker 388 is offline
Old 03-10-2006 | 08:31 PM
Beak Boater's Avatar
Charter Member # 545
Default Re: Cutting the Difesser Ring
Rob
I am no expert, but the way it was explained to me is, the difusser ring helps to seal the props blades when getting on plane. It helps keep exhaust gas's from getting in the props blades and causing cavitation, thus helps the boat get on plane quicker. Once on plane it doesnt have any positive effect unless you are moving at a very slow speed. But because of the flare in the ring it can cause added drag and slow you down a few mph. How many varies with set up. Its a trade off. If you remove it or modify it, planing ability may be sacrificed, they can be removed and then welded back on if the modification doesnt work to your satisfaction. Im sure Brett, Julie, or Matt can explain it better.
Beak Boater is offline
Old 03-11-2006 | 07:10 AM
redfountain420s's Avatar
i personaly saw the differance on my buddys boat (mv35) his 35 ft fountain runs 104mph and he cut off the difusser ring and the boat ran 109.9 on radar . i never thought it would make a differance but it did
kevin
redfountain420s is offline
Old 03-11-2006 | 11:05 AM
Harper220's Avatar
difesser? come on now, spell check is free...
Harper220 is offline
Old 03-11-2006 | 12:38 PM
Rob
I copied and pasted it from another page Is this how daddy ? diffuser
Old 03-11-2006 | 12:51 PM
Harper220's Avatar
Now I know what you're talking about...
My understanding is that it helps with planing to cut down on blowout.
Old 03-11-2006 | 01:09 PM
Rob
Where I come from ,Mississippi we don't talk or spell to good
What about speed ?I have no problem at all getting on plane I don't even need tabs.
Old 03-12-2006 | 11:36 AM
Harper220's Avatar
I believe you can gain a little speed by removing the difusser ring. Not sure how much though.
Old 03-12-2006 | 01:28 PM
375stinger's Avatar
how can i tell if i have one? we have hydromotive iv. thanks
375stinger is offline
Old 03-12-2006 | 01:37 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Look at the prop on the end. Either you gots it or you don't.
US1 Fountain is offline
