Need Help On Prop Size >
Old 03-11-2006 | 09:34 AM
sakoutis3's Avatar
Default Need Help On Prop Size
What size props should I be using on a 51' Outer Limits with triple 575's . The boat presently has 27p I'm thinking it should be more like 31's.
sakoutis3 is offline
Old 03-13-2006 | 06:35 PM
throttleup's Avatar
Default Re: Need Help On Prop Size
What is the wet weight of the boat?
What HP and what is the RPM at which it is produced?
What Drive and gear ratio?
With a little Info I will try to help you.
Julie
throttleup is offline
Old 03-14-2006 | 08:32 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Need Help On Prop Size
A base line with the props you have will greatly help us to give you the best advice we can.
However, I would agree with you that the 27's will be quite small for the set up.
[email protected]
bbladesprops is offline
Old 05-23-2006 | 05:20 PM
sakoutis3's Avatar
Just bringing this back to the top. I'll be calling you guys now that my boat is back.
deanpp
Prop Talk
8
05-10-2007 09:49 AM
Mikey Likes It
Prop Talk
2
04-03-2006 09:25 PM
24Baja
0
06-17-2005 01:29 PM
z.zuperboat
4
04-16-2004 07:28 PM
Dave1972
0
07-08-2002 10:37 AM
