Scarab III props
Originally Posted by throttleup
I would get a little seat time and then baseline your props and start testing props to see what props help you to achieve your goals.
Julie
Julie
finally got the boat in and i ran 56mph at 5000rpm and 42mph at 4000rpm with the 23" quicksilvers. should i be able to spin a 23" 4 blade?
08 OPA High Points Champion
Dependant on the diameter of your 23P 3B's you may loose some RPM with the addtional blade. But I would guess that the diameter of your 3B props is smaller than that of the Bravo I 4B. THe larger diameter of the 4B will also decrease the RPM as well.
Julie
Julie
what would be a better prop the B1 or the Q-IV. i have been told the Hydro works well with this hull. what is the differance in the two props?
Originally Posted by Scarab3DMC
I run QIV'S...boat handles 100% better...she felt slippery with the 3 blades...
