Bravo One compared to Chopper II >
Old 03-26-2006 | 07:42 AM
Default Bravo One compared to Chopper II
HI!
The Bravo One 4 blade prop is lower in pitch than stamped. How does a Chopper II 3 blade 28 compare in pitch to a Bravo One 4 blade prop? If the Bravo One is lower in pitch than the 28 stamped, how does it compare to a 3 blade. Normally a 4 blade compensate for pitch.
Cheeeers, Toffen G
Toffen is offline
Old 03-26-2006 | 11:11 AM
throttleup's Avatar
Default Re: Bravo One compared to Chopper II
They are a little shy on pitch Toffen.
Julie
throttleup is offline
Old 03-27-2006 | 05:54 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Bravo One compared to Chopper II
Do you mean how do they compare in pitch or how do they compare in general?
They are completely different in geometry and characteristics if that is that is what you are asking.
As far as pitch, the chopper is higher but yes the extra blade and hub can equalize the rpm outcome.
[email protected]
bbladesprops is offline
Old 03-28-2006 | 11:53 AM
Hi!
Thanks. It was the pitch comparison I ws after.
But how will you compare the caracteristics between the Bravo One 4 blade and the Tempest 3 blade?
Cheeeers, Toffen G
Toffen is offline
tomas_wallin
Drives and Lower Units
2
10-17-2007 07:57 PM
tomas_wallin
7
01-12-2006 01:28 PM
skaterboy
1
02-11-2005 09:42 PM
thedonz
12-21-2004 04:44 PM
