#6 props on a #5 drive???? >
Old 04-05-2006 | 01:16 PM
Default #6 props on a #5 drive????
I just put a set of #5 drives on my boat. I have an chance to get some props to try but they are for a #6 drive. The #6 prop shaft has more splines and is bigger in diameter than my #5 drive shaft. Is there a reducer that I can buy that will work for me? Thanks in advance
Drinking Fountain is offline
Old 04-05-2006 | 02:24 PM
Default Re: #6 props on a #5 drive????
The spline count should be the same; you'll need a 3A, 4A, #5 Merc plastic bushing for each prop.
Due
Dueclaws is offline
Old 04-06-2006 | 09:05 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: #6 props on a #5 drive????
The bushing part # is 822973. We have them in stock if you can't find them. Also have the c-clips and new nuts.
By the way, your shaft is 1.75" compared to the 1.88" of the #6. They both use 26 splines.
[email protected]
bbladesprops is offline
LAXBAJA
Prop Talk
13
12-13-2007 04:12 PM
BajaFresh
Prop Talk
3
07-10-2007 01:00 AM
JoeD
05-25-2005 08:07 PM
CN24
1
12-31-2004 05:33 PM
HOUSTONPROP
11-30-2002 07:02 PM
