Prop for Concept w/ 250efi >
Old 04-20-2006 | 01:17 PM
BAJA WILL's Avatar
Registered User
Default Prop for Concept w/ 250efi
Got a quick question, we just purchased a 2001 27 concept w/ single 250efi, Concept said the boat came with a 23 pitch Mirage, my question is is their different diameters for these props and if so what diameter do I need? Also if their are any others props that would work??
WILL
BAJA WILL is offline
Old 04-20-2006 | 02:34 PM
throttleup's Avatar
Default Re: Prop for Concept w/ 250efi
Hello Will,
I would recommend that you try a 22P Bravo I on the boat, it is very common on the Concepts. The diameter is that of about 14 7/8 ish with your Mirage Plus at a 14 5/8ths.
Julie
throttleup is offline
Old 04-21-2006 | 07:03 AM
BAJA WILL's Avatar
Registered User
Julie, Thank you
Old 04-21-2006 | 10:20 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Prop for Concept w/ 250efi
Just did some extensive testing on the exact set up.
Best prop, to date 14x23 Mazco.
Second, 23 Mirage Plus.
Of course every identical boat is different.
By the way, to answer your question, the Mirage family comes in different diameter sizes with each pitch change. But, only one diameter is available with each of the pitches.
Hope that makes sense?
[email protected]
bbladesprops is offline
Old 05-05-2006 | 10:37 AM
Rocco's Avatar
What are the speed #'s for these props ? Is the Mazco a 4 blade (Hp4)
Rocco is offline
Old 05-08-2006 | 08:57 AM
Rocco's Avatar
Ttt
Rocco is offline
Old 05-08-2006 | 08:41 PM
Yes the Mazco is a 4bl. I have to recheck the numbers and let you know. Sorry for the delay, call us if you want all the info.
[email protected]
rchevelle71
12-12-2007 08:31 AM
superdave
06-28-2002 10:24 PM
THE BULL
3
05-02-2002 09:42 PM
