Bravo Three question for the Prop Experts >
Old 05-12-2006 | 11:48 AM
Default Re: Bravo Three question for the Prop Experts
Here is a picture of the props as they where mounted when I picked up the boat from the marina.
They used to be a spare set of 28"P's that the marina had sent out to re-pitched to the largest possible pitch... as a baseline test for the HP525.
I was told that they were cupped and and re-pitched to 30.5" and now I can pull close to 5,200RPM's with a full tank and 3 persons on board.
Can you tell from the picture if the prop's are one spine off? They looked off to me and hence the question about them needing to be aligned.
The workmanship on the props is so so...I can feel a few flaws by just running my fingers accross the blades. I'll send my original balanced 28"P's to be re-done by one of the OSO advertisers for a final prop adjustment...if there is such a thing
Jamal
Attached Thumbnails Bravo Three question for the Prop Experts-img_0457email.jpg
S4Hadi is offline
Old 05-13-2006 | 12:05 AM
SeaRay Jim's Avatar
It looks about right. 1 spline is pretty noticable.
Did they also add cup to the front prop?
SeaRay Jim is offline
Old 05-16-2006 | 08:37 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Bravo Three question for the Prop Experts
We rework these propellers often. If you need adjustments to correct rpm levels, give us a call.
[email protected]
bbladesprops is offline
Pascagoula Run
9
01-13-2013 09:20 AM
Fenderjack
Prop Talk
2
07-12-2007 10:09 PM
4mulafastech
Prop Talk
1
01-18-2006 06:12 PM
CN24
Prop Talk
3
06-30-2005 11:24 AM
Hot Boat
6
02-10-2002 08:03 PM
