hell me pick prop >
hell me pick prop
hell me pick prop
Old 05-10-2006 | 06:43 PM
nocigarette's Avatar
Default hell me pick prop
I know there is guy here to sell me the propeller i need but how can i shoose the right one...........I know am running a 15.25x25 3 blade cleaver.....The boat is a 27 magnum with A #3 speedmaster and a 700 hoarse na motor.....The problem is i am only turning the motor at 5600 and i need to spin up to at least 6200...The motor is built to handle it but i need more rpm.........................hellllllllllllpppppppp pppppp
nocigarette is offline
Old 05-12-2006 | 03:22 PM
throttleup's Avatar
Default Re: hell me pick prop
If you were to drop to a 22P of like diameter you would pick up the additional RPM you are looking for. You could consider a diameter reduction and downpitching to acquire some of the RPM you are looking for as well.
Julie
throttleup is offline
Old 05-16-2006 | 08:42 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: hell me pick prop
Are you sure it is 19 splines and not 26?
I don't think that decreasing diameter is a good idea. Are you sure 6200 is appropriate?
[email protected]
bbladesprops is offline
Old 05-17-2006 | 08:58 PM
brett i just talked to scott today from speed and custom he assured me you could help me.............great guy "scott" i will call you in a couple of days and see what you can come up with...................MAN YOU COME HIGHLY RECOMMENDED...............
THANKS AGAIN
Old 05-18-2006 | 09:37 AM
Thank you, call when you can.
[email protected]
customryder
11-12-2005 05:24 AM
grimmy
Prop Talk
3
04-25-2005 07:50 AM
Shah Mat
11
12-29-2004 03:50 PM
enticer
08-22-2002 07:50 AM
