Prop Help 1991 Mach 1 >
Old 05-25-2006 | 04:48 PM
Default Prop Help 1991 Mach 1
I am looking for prop help on a 1991 Mach 1. Has a 502 mag, and a rough estimate weight is about 6200. I am currently running a Mirage 21, and wanted some others opinions. Thanks in advance for the help.
hawkfan11 is offline
Old 05-25-2006 | 05:48 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Prop Help 1991 Mach 1
Concider the Revolution 4. They have great all around performance. We have them in our loaner program.
[email protected]
bbladesprops is offline
Old 05-26-2006 | 07:41 AM
throttleup's Avatar
Default Re: Prop Help 1991 Mach 1
hawkfan11,
Do you have any performance data to assist in making a suggestion for you.
What is yoru WOT RPM?
What is your WOT MPH via GPS?
What is your gear ratio?
Julie
throttleup is offline
Old 05-27-2006 | 08:42 PM
Gear ration is 1:50
Right now WOT RPM is only 4400-4500
I don't know MPH GPS, but according to my speedo which is not all that accurate abotu 57 or 58.
Again I am currently running a 21 Mirage and it seems to be real sluggish getting on plane. Thanks in advance for your help.
1991 502 Mag
Old 05-31-2006 | 06:47 PM
Any suggestions Pro-prop or Throttle up
Old 06-02-2006 | 01:09 PM
Having an accurate speed is critical in determining the efficiency of the boat.
The use of a 4blade will definitely improve the ability to get on plane.
Get some good speed vs. rpm numbers and we can discuss your options from there.
[email protected]
Lofty
Swap Shop
1
07-31-2008 10:30 AM
Magnum25
3
10-19-2006 08:37 PM
Gilman
Fountain
6
06-08-2006 07:16 PM
JP
Scarab
3
02-11-2006 08:55 AM
Stormrider
Prop Talk
4
06-28-2005 08:18 PM
