Prop Pitch >
Prop Pitch
Prop Pitch
Old 06-12-2006 | 05:27 PM
Default Prop Pitch
I have a 1989 38' Scarab w TRS drives and 525 HP.
What prop and pitch?
white scarab is offline
Old 06-13-2006 | 05:14 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Prop Pitch
Depending on weight...
23 or 25 Mirage Plus.
[email protected]
bbladesprops is offline
Old 06-13-2006 | 05:18 PM
Default Re: Prop Pitch
The boat is approx. 9500 LBS
Old 06-13-2006 | 05:27 PM
What rpm do you wish to turn the engines?
What is your gear ratio?
Have you run other props?
Is cruising or speed most important to you?
[email protected]
Old 06-13-2006 | 06:26 PM
I run w/ 23 pitch Bravo props.
My motors should run @ 5,200 RPM's.
Gear Ratio ? I don't know but I will find out. They are Mer Cruiser TRS Drives and transmissions.
prostockcat
4
05-11-2008 08:45 PM
rch662
Superboat
11
09-02-2006 10:05 PM
white scarab
Scarab
0
06-12-2006 05:19 PM
Smitty
Prop Talk
1
06-06-2005 03:13 PM
bvs629
23
03-19-2003 11:07 AM
