MESSAGE FOR B-BLADES-Midnight Express >
Old 06-17-2006 | 02:54 PM
Enforcer2's Avatar
From: Ocean Pines, Maryland. Wish I was at MANGOS in MIAMI!
Default MESSAGE FOR B-BLADES-Midnight Express
RE: 37 Midnight CC with trips 225 opti's
total length 39
24" BRACKET
Bobs lower units jacked way up
12,500 lbs with 100 gallons of fuel
bottom painted
SPEED TAKEN IN HAND HELD RADAR
Okay, finally got some solid numbers for ya.
Tried 22 Bravo ones 24 Bravo Ones and ran one 24 B-1 in center. Here they are.
22b-1's
3000 27
3500 34
4000 38
4500 42
5000 50
5500 52
5900 55
24 B-1's
3000 29
3500 34
4000 43
4500 49**
5000 54 **
5200-5300 trimmed way out 58 mph
22 on outers 24 in center
3000 28
3500 36
4000 40
4500 44
5000 50
5600 Center and STBD 5800 Port 56
Should I know lower the center engine one hole ( prop shaft even with bottom), like you already told me too or should I try the 23 Rev 4's, or lab the 24's???? Are go to larger Mirage's????????
24 B-1s performance is sluggish at take off,
22's have strong acceleration all the way through but I am reving too much, 24 in center with 22's are difficult to keep even RPMS and the trim is very different with the three.
Thanks, Tony
Ocean City Maryland
Attached Thumbnails MESSAGE FOR B-BLADES-Midnight Express-lower-units-1.jpg   MESSAGE FOR B-BLADES-Midnight Express-lower-units-5.jpg   MESSAGE FOR B-BLADES-Midnight Express-midnight-inlet-4.jpg
Enforcer2 is offline
Old 06-18-2006 | 12:36 AM
Enforcer2's Avatar
Default Re: MESSAGE FOR B-BLADES-Midnight Express
B-Blades forgot the numbers that the 21 mirages were putting up with the engines mounted two holes lower on sides and three in center.
4000 39
4500 45
5000 49
5900 55
Old 06-19-2006 | 05:59 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: MESSAGE FOR B-BLADES-Midnight Express
With 12% slip, I'd like to work with the 24 B1's.
Call when you can and we'll go through the options (including the cnt engine).
[email protected]
bbladesprops is offline
Old 06-20-2006 | 11:11 AM
Enforcer2's Avatar
Thanks Brett,
Tony
keyskiller
Midnight Express
5
06-06-2011 02:30 PM
andym7080
Midnight Express
0
02-15-2008 12:44 PM
Stormrider
05-24-2006 06:03 PM
nick k
01-06-2006 11:00 PM
Enforcer2
11-15-2005 05:34 PM
