2000 Baja 24 ft 454 EFI >
Old 08-01-2006 | 03:44 PM
Default 2000 Baja 24 ft 454 EFI
This boat has a closed bow and 454 EFI (325hp) bravo1 what prop should my friend run??? I assume it is 1.5 ratio drive he had a three blade ballistic on it. He doesn't know the pitch on it.
imagecat is offline
Old 08-01-2006 | 05:18 PM
throttleup's Avatar
Default Re: 2000 Baja 24 ft 454 EFI
A 23 pitch prop would be a good start. Something like a Mirage 23 would be a good starting point and go from there.
You will want that motor running about 4400-4600 at max speed.
throttleup is offline
Old 08-01-2006 | 05:25 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: 2000 Baja 24 ft 454 EFI
I agree the Mirage Plus is the prop to try. 23 "may" be too high. Try any one you can find from 19, 21 or 23 pitch.
[email protected]
bbladesprops is offline
Formula311-SR1
2
10-08-2007 09:04 AM
Buddy Novak
12
08-07-2004 10:37 PM
blown formula
31
06-10-2003 06:59 PM
hotrodtodd32
11
02-15-2003 03:36 PM
