Prop slip help...whats good? >
Old 08-08-2006 | 09:45 PM
Default Prop slip help...whats good?
I have a sunsation 288, 1.5 Bravo XR and im spinning a 4 blade bravo 1 30 pitch. The prop has had work done to it by the previous owner but im not exactly sure what but the blades have been thinned. Im running 81 at 5200 rpms which calculates about 18% slip. This sounds a little high to me? Whats good for that boat, I was thinking about 12%? Also it slips a little when just getting up on plane with a heavy load and I have trouble keeping it at a low planing speed without first going faster and then slowing down. Any ideas a different prop that might work??? By the way the rpms are right in the range I want to be in for the motor.
dagah2x is offline
Old 08-09-2006 | 06:52 AM
throttleup's Avatar
Default Re: Prop slip help...whats good?
There are many factors that influence slip.
In your case from what you are describing it sounds as if your prop has been lab finished. The other possibility is that your drive is too high.
It's hard to say for sure without some baseline numbers with a stock prop. Those are generally the most consistent as each lab prop will be a little different than the next depending on it's application.
You may want to consider a stock 28 Bravo 1. It may address your complaints. If not the performance numbers from the stock 28 can be used to diagnose what the exact problem is with your boat.
Matt
throttleup is offline
Old 08-09-2006 | 09:35 AM
Matt
I believe you guys are the ones that did the prop, would you have a record of what was done if I give you the previous owners name? I do have access to a stock Bravo 1 28 to try next week.
dagah2x is offline
Old 08-09-2006 | 10:02 AM
throttleup's Avatar
Yes, we should have the info. Shoot me a PM if you liek and I can look it up.
Julie
Old 08-10-2006 | 05:29 PM
Looks like to me, your slip percentage is closer to 16%.
convincor253 is offline
Old 08-10-2006 | 05:38 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Prop slip help...whats good?
You are just under 16%. Not great, not terrible. You are in a balancing act mode with your hull. Decreasing slip now may require losing a small amount of rpm or going down in pitch to get the rpm back. That means the speed may stay the same. As stated before, see what has been done to the propeller first.
[email protected]
bbladesprops is offline
Old 08-10-2006 | 05:51 PM
Hummmm, I used this on-line calculator, is it wrong? Whats the formula that you guys use? I want to make sure im doing it right or its a wate of time....
http://www.rbbi.com/folders/prop/propcalc.htm
dagah2x is offline
Old 08-10-2006 | 06:49 PM
Bravo 1 props vary from .7 to 1.3 inches below the stamped pitch. They are all different from prop to prop and working them changes things too. Use 1 inch to .75 inches under the pitch when calculating.
[email protected]
Old 08-10-2006 | 07:45 PM
Interesting......, I guess its not as simple as I though. Thanks.
dagah2x is offline
Old 08-10-2006 | 08:56 PM
waybomb's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
Is this the correct formula?
1 - {(MPH/60) / [(rpm / ratio x pitch)/12/5280]} = prop slip percentage
waybomb is offline
