-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Bravo-1 vs. Revolution-4 (Labbed vs. Stock) (https://www.offshoreonly.com/forums/prop-talk/139680-bravo-1-vs-revolution-4-labbed-vs-stock.html)
StillHaulin@63 09-05-2006 05:16 PM
I was planning to put a labbed 24" Bravo-1 4-blade on my Baja 232 (454 Mag MPI w B1) which is presently running a stock 23" Mirage/PLUS 3-blade prop. A cleaner holeshot, less turning cavitation and mid-range throttle control are key objectives, not so much top end.
It was suggested by a knowledgable dealer to consider a stock 23" Revolution-4 prop (or stock 22" Bravo-1) in lieu of the labbed 24" Bravo-1 due to possible excess slippage of the labbed prop. Anyone have any experience with this type of situation?
ReggieRaft 09-05-2006 05:48 PM
Re: Bravo-1 vs. Revolution-4 (Labbed vs. Stock)
Go with the Rev 4 23 pitch. You will be very happy.
bbladesprops 09-05-2006 09:00 PM
We set these up daily with REV 4's. Give us a call and we'll discuss some test REV 4 props for you to try.
1987-242SS454 09-07-2006 07:13 AM
I really like the Rev 4 BBlades just sent me for my boat, I don't have any Bravo experience so I really cant compare them though.
Queenie 09-07-2006 09:19 AM
We have the 23 pitch 4 blade Revolutions on our boat and we can't say enough to how well the boat responds to these props.
We tried 12 to 15 sets of props on our 1988 31 ft Stinger. This was the only prop to get the bow up and air under the boat. We're going to lab them this winter as we know we'll see some slight improvement with our speed and RPM's. We picked up several RPM's and increased our speed by 2-3MPH.
Pat McPherson 09-08-2006 11:16 AM
I'm pretty happy with the labbed 28p Bravo 1 that BBlades did for me, but I wonder how my boat would run with a Rev 4?
The Rev 4 seems to push old school straight V bottom boats vary well.
What is the max pitch offered these days?
I run a 26p or labbed 28p Bravo 1; is there a comparable Rev 4?
509 SC 09-08-2006 08:50 PM
I'm not positive but I believe the largest pitch offered is a 23". Steve
Pat McPherson 09-11-2006 09:59 AM
I messed around with Merc's prop selector and got it to spit out a 25p Rev 4. After that it only suggests Mirage + or Bravo 1.
I think I'd need a 27p Rev 4...
SPEEDFREAKS 10-01-2006 09:24 AM
WHAT YOU DID NOT SAY WAS WHAT RPM YOU ARE SPINNING
A 4 BLADE WILL SLIP LESS THENE 3 BLADE SO A 224B IS A GOOD START LABBED PROPS ARE GOOD BUT THERE ARE NOT MENT TO USE EVERY DAY THERE THINED OUT AND THEY GET WEEK I RIP A EAR OFF OF ONE AND I DIN NOT HIT ANYTHING IT JUST GOT WEEK AND BROKE
bbladesprops 10-02-2006 07:00 PM
25 is the largest Rev 4 made. I am still lobbying for 27's but with all the other things going on right now, my wishes are falling on deaf ears. I know we would have many applications they would work on.
I should of pushed harder when I still worked there.
