Outboard Height
3 Attachment(s)
Need expert advice on set up. SHOULD I RAISE THE OUTERS SO THE PROP SHAFTS ARE EVEN WITH BOTTOM LIKE CENTER ??? (originally set up with quad 200's - outers were 20" shafts and inners were 25" shafts_
37 Midnight Express triple 225 optis (outers 25 center 30") 24" bracket 12,500lbs w/approx 100g fuel 22 Bravo ones 5900 rpm top speed 56 cruise 4000 41mph 4500 45mph (Good all around performance) fuel tanks -middle of boat stern to console /console to bow and side tanks console to bow.(1,000 gallons-don't use capacity) Boat is stern heavy. Tried Mirages, Bravo Ones and Rev fours. 58mph w/ Rev fours @ 5400 RPM sluggish hole shot Thanks Tony |
Re: Outboard Height
Hey Tony,
Give it a shot and we'll compare notes post the testing. Your boat has been a pleasent surprise already compared to the norm. We know we can improve the current hole shot / ability to get on plane. |
Re: Outboard Height
Thanks Brett, you and your guys have been awesome. Just wanted to see if I could get someone that has experience with this set up.
Tried Scream and Fly waiteing for response there also. Don't worry, you know I will be calling, :D |
Re: Outboard Height
Brett this is a post from BROWNIE. THE KING HAS SPOKEN. :cool: NOW WHAT!!!! ONE MORE ENGINE
While you might get a little more speed with the outside engines raised, in rough water or running hard in beam seas, the outside engines will clear the water a lot, and beat the hell out of the shafts and gears. I would leave it alone. |
| All times are GMT -5. The time now is 11:03 AM. |
