what prop nexted >
what prop nexted
what prop nexted
Old 09-28-2006 | 10:54 PM
AIR TIME's Avatar
Default Re: what prop nexted
there's a 25 ol with a box getting 81mph at 5300rpm what is his slip # prop is a b1 28 at 300more rpm 26 I would think would be at 81 or 5700 or 5800 be 83 what is the cal you use to find the slip? thanks art oh his is raised 3''
AIR TIME is offline
Old 09-29-2006 | 03:02 AM
articfriends's Avatar
I tried a 28 5 blade maximus a few weeks ago,boat went another 1 mph slower on top end,stern lifted and bow steered,plus sheared off a prop shaft.You would probably be wasting your time unless you get one really worked on and have alot of time to have it modified,test,modified,test,re-test etc. It did have excellent cruise though,Smitty
Attached Thumbnails what prop nexted-dsc04701.jpg   what prop nexted-dsc04705.jpg   what prop nexted-dsc04698.jpg
articfriends is offline
Old 09-29-2006 | 10:34 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: what prop nexted
In general 5 blade props aren't the answer to top speed on deep V's. I have been telling people that for years. There are exceptions to every rule though. Bajas with higher X dimension from shorty case with big HP can obtain a high enough running attitudes to not bow steer with 5 blades. We do also adjust the diameter to help the overall running attitude. The correct 3 or 4 blade propeller on a Baja is still the recommendation for all around performance.
There are many reasons a prop shaft can break. Just bolting on a 5 blade propeller isn't one of the main reasons to loose a prop shaft.
[email protected]
bbladesprops is offline
Old 09-29-2006 | 11:20 AM
Boat was straining hard from 4800 to 5700 with 28 pitch 5 blade maximus,taking 3 times longer to pull the rpm's than with a 30 labbed,i think it just pushed the shaft past its limit when I was prop testing. What I think is shaft was at 95 % of its limit with the big tq and running my 30 and 32 labbed props,the 28 5 blade slipping signifigantly less put it to the failure point,it might have just been coincindental but there are no more 5 blades in my future ,Smitty
Old 09-30-2006 | 01:07 PM
AIR TIME's Avatar
Thumbs up Re: what prop nexted
81 at 5800to 5900 flat water in the bay and river river 80 to 81 up and down my buddy was cutting his lawn 2 miles away he could here me on his lawnmower and I ran 10 passes easy love MY dry S/M LOOKS LIKE A 28 5BLADE this winteror 28/30b1
AIR TIME is offline
Old 10-03-2006 | 06:39 PM
AIR TIME's Avatar
all set thanks bblades good talking to you .
AIR TIME is offline
Sick Stinger
Velocity
9
02-07-2008 11:39 AM
boatinbill
07-26-2002 09:58 AM
MIKEHTMSR24
07-22-2002 03:18 PM
MIKEHTMSR24
0
07-22-2002 01:40 PM
