-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Prop blow out 100+ MPH ??? (https://www.offshoreonly.com/forums/prop-talk/142757-prop-blow-out-100-mph.html)
Strip Poker 388 10-14-2006 04:20 PM
2 Attachment(s)
At what point does a stock Bravo foot blow out the prop.At what speed would you think is the limit on a stock bravo foot and when would a nose cone or a aftermarket style foot would benefit speed????????
Mine is a 2001 low water pick up style bravo.....388 Hustler step bottom.1.30 gear.30p stock bravo one props.
Test at Full tank of gas & flat water
3000 rpm was 47mph
3500 ..............63
4000...............73
5000...............88 and light on fuel was 90mph
WFO one motor around 5750 and the other at 5600 it gets 101mph porpoising bad!!!
http://www.zippyvideos.com/6183811926072336/resize_001/
I am just wondering if a better foot would help?I have had the new B-Max crescent lowers on order since May :(
Rob :drink:
.Pick
http://www3.filehost.to/files/2006-0...1__Medium_.jpg
iamfaster 10-14-2006 07:49 PM
Re: Prop blow out 100+ MPH ???
Stock drive height, or did you change?
BenPerfected 10-14-2006 08:20 PM
I would say you need some bottom work. I don't know much about the the stepped hulls, but it appears that you are running out of hull surface (strakes) to hold the bow up. Re-look at your tape and note the moving spray line. Half-way in between, look and see what strakes are there to support/hold the bow. If there is nothing but a flat surface, you likely have found the problem.
If any of this makes sense, i can tell you what was done to my hull to get my bow dead still at 100MPH+.
Sprague
BenPerfected 10-14-2006 08:33 PM
One other comment. I found 4 MPH with the IMCO lower units at the same X as the Bravo lowers at Lake X. I move from 93 to 97 MPH with everything else the same.
I then started raising the X and ended at 101 MPH with the prop shafts 1.25" below the bottom. Non-stepped hull w/engines on 35" centers.
mtm 10-15-2006 03:32 AM
Rob what's up have u run the props turning in?
I like the way my boats been running with props in last run with 2- shortys props turning in 6000rpm 32pitch old beat up bravo props 101mph flat water and more still left
Mike
mtm 10-15-2006 03:38 AM
1 Attachment(s)
I also tried these today and broke both drives
iamfaster 10-15-2006 06:47 AM
Ben, boat, power, stand-off boxs??
Strip Poker 388 10-15-2006 10:37 AM
Its stock X. I know the hull has to much stern lift built in to it, Joe at Hustler said do not cut into the strake .it cuts into the stringer and you have to re brace the inside . Some Ive talked to said it helped and others said no. I know it will hurt cruz speed.Joe also said that turning the props in will make it handle worse,chine walking have more Stearn lift.He also said that the hull wasn't designed to go that fast.So I figure I'm hitting a wall a little over 100? Now I am getting the hang of driving it with out any tabs keeping it from chine walking.its just porpoising bad.I guess foots and props work will help that?
Just wondering if the foot will make much difference ??
customryder 10-15-2006 12:13 PM
what is the prop dia?
articfriends 10-15-2006 12:40 PM
2 Attachment(s)
We ought to start a thread on how quickly a 5 blade wipes out bravo drives. I have never broke a prop shaft EVER and took off my 32 pitch merc labbed,tossed on a stock maximus and after 10-12 1-4 minute wide open passes sheared off a prop shaft,Smitty
