Bravo 1 26P >
Bravo 1 26P
Bravo 1 26P
Old 11-28-2006 | 03:18 PM
gsmith9898's Avatar
Default Re: Bravo 1 26P
removable hub. I'm not sure they made a solid hub bravo 4 blade.
gsmith9898 is offline
Old 11-28-2006 | 03:57 PM
Rage's Avatar
I'm not either but someone else advertized a solid hub Bravo 1 so I thought it best to ask just in case. I need to finish ECU dial in and dyno test before final decision on prop change. If I am in the market then I will check to see if it is still available.
Rage is offline
Old 11-28-2006 | 06:40 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Bravo 1 26P
Just a quick history note.
We came out with the flo-torq 2 system in the 1996 era Mercury offerings (current with what we use today). It was a real pain considering all the B1, Mirage, main line props and the OB cleavers and choppers had to be changed over. What a great move though since it allowed all engine manufacturers to run Merc props.
Anyway, prior that, yes there was a cast in solid hub Bravo 1 propeller. I believe it was what we called a A50 casting. Man, were does the time go!?
[email protected]
bbladesprops is offline
Old 11-28-2006 | 07:13 PM
gsmith9898's Avatar
I have seen people call them solid hubs thinking that the center did not come out.
Old 11-29-2006 | 08:24 AM
No, I mean there was a actual cast in solid hub before the press in solid hub we have today. It had 4 long web struts and a relatively thin walled splined center hub. It used a different thrust hub than today's propellers. Totally different but it was a solid hub.
[email protected]
FeverMike
Prop Talk
1
02-22-2008 01:16 PM
TCH6868
Prop Talk
2
06-04-2007 07:50 PM
BRB
Baja
11
01-06-2004 10:32 PM
Tantrum
05-09-2002 09:08 PM
Tantrum
03-28-2002 05:50 PM
