28P bravo vs 28 Hydro >
Old 12-04-2006 | 04:39 PM
berns29scarab's Avatar
Default 28P bravo vs 28 Hydro
on a 353 fastec with 502 mpi's twin step currently tapping the limiters with the stock non labbed bravo 1's...what diff would be seen between these 2 props ?
berns29scarab is offline
Old 12-04-2006 | 04:54 PM
throttleup's Avatar
Default Re: 28P bravo vs 28 Hydro
Hydro's will lift the stern more so than a Bravo therefore Bravo I props have less stern lift.
Julie
throttleup is offline
Old 12-06-2006 | 06:30 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: 28P bravo vs 28 Hydro
The Bravo 1 will have better mid range cruising efficiency. They may also put you on plane faster. The hydro's will pull the R's down a little more than the B1's. Depending on the weight and balance of the boat, the Hydro's could have a 1-2 mph top end advantage because of the R's you can turn with the B1's.
Every identical boat is different so back to back testing with good note taking is the best way to getting your answers.
[email protected]
bbladesprops is offline
KMP
Wanted
8
04-01-2008 08:50 PM
29KILROY
07-17-2007 05:34 PM
velocitypwrbtr
Prop Talk
3
02-23-2006 07:18 PM
MIKE H
Prop Talk
5
08-22-2005 06:54 PM
