Hoping for a little more >
Old 03-14-2007 | 02:15 PM
florida gator's Avatar
Default Hoping for a little more
New boat isn't getting as much speed as I would like. 26' Wellcraft Scarab Sport w/a 225 Johnson. Motor checks out fine. Prop is 14x20 3 blade stainless. Turning 5600 RPM and 43 on GPS. Local dealer said all sounds well. Any ideas?
florida gator is offline
Old 03-14-2007 | 02:28 PM
throttleup's Avatar
Considering the boat and power your speed seems appropriate.
If you want to pick up a little more speed you may want to consider a pair of 250 Etec's or a pair of the new Merc 300 opti's. That would give you a speed increase you would really notice!
Matt
throttleup is offline
Old 03-14-2007 | 03:33 PM
Thanks for the diappointing news.
Max power is 300. I probably will upgrade to a 300 opti at some point but not just yet. I have a hard time justifying that with a perfectly fine motor.
Old 03-14-2007 | 08:09 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
What's your gear ratio?
A little more diameter in the prop and precise geometry may help the over all cause. Most likely it won't be big steps though.
[email protected]
bbladesprops is offline
Old 03-15-2007 | 01:28 PM
Not sure the ratio. I would assume everything is stock.
Old 03-15-2007 | 07:39 PM
Smile
With the year designation of your OB we can check the g.r.
I don't know it off the top of my head. I ran the numbers with my ratio memory and it seemed your efficiancy was a little low.
If I'm right, top speed may not be able to be helped to much concidering the rig, but overall performance may be tweaked a some.
[email protected]
Old 03-15-2007 | 08:08 PM
throttleup's Avatar
You have a 1.86 gear ratio.
Old 03-16-2007 | 08:54 AM
Smile
Thanks,
That would make the efficiancy pretty poor at WOT.
24-25% slip. A little more diam. might help.
[email protected]
Old 03-18-2007 | 07:58 AM
Originally Posted by bbladesprops
Thanks,
When you say efficiency, is that primarily cruising or should I get a little more speed?
Old 03-19-2007 | 09:46 AM
Smile
More could be gained across the board.
Do you have anything else you could test with?
[email protected]
