Unrealistic low prop slip
Friend of mine has a 29 ft rib with twin 250 verado's
Spinning (brand new) 23 P Rev 4 props @ 6010 rpm and seeing 70 mph on 2 different GPS
After prop slip calculation theoretical topspeed = 71 mph meaning this rig only has 1 % propslip which is unrealistic
Merc's website stated for Verado 250 only 1 gear ratio 1.85
Where is the error or are these props so perfect ???
GPS's can be off, Tach's are always slightly off.
Example........
True speed...69 mph
True rpm........6250
True slip.........6.22%
Ribs can be real efficiant.
Example........
True speed...69 mph
[email protected]
[email protected]
Yes, speed was GPS measured (by two different GPS 1 handheld / 1 fixe in the boat) in kph but converted to mph when putting info on this board.
Changed props last week => almost same story
Rev4 21P turning at rev limiter @ 6400 rpm GPS speed is 106 kph = 66,25 mph
Calculating slip = < 4%
Mirage 3 BL 23P hitting rev limiter 6400 RPM
Top speed was 113 kph = 71 mph = < 5% prop slip
Again very unrealistic low prop slip numbers IMO
Now lets try some Bravo 1 4 blades (or even better Lab finished ones)
With these numbers, Labs will make you fly!
[email protected]
[email protected]
