What is going on ??? >
Old 04-15-2007 | 01:12 AM
Default What is going on ???
I have run 3 props: a 25 3 blade a 27 3 blade and a 26 4 blade and I still can only get 68 mph out of my boat. The boat has a 500 hp 600 lb of torque at 4100 rpm's. The only diff is that the 4 blade does not seem to get the nose out of the water as much.
perform330 is offline
Old 04-15-2007 | 01:25 AM
HiPerf2000's Avatar
sounds like you have too much pitch. what brand prop are you running? what size/weight boat do you have? you want to turn at least 4800 rpms.
i have a 24p 4 blade hydromotive Q4 for sale if it can work for you.
HiPerf2000 is offline
Old 04-15-2007 | 02:48 AM
What rpms are you spinning each prop at??????
Length and weight of boat???????
Griff is offline
Old 04-15-2007 | 10:10 AM
Liquidsation's Avatar
We need more data. Also check what drive and gear ratio you have.
Liquidsation is offline
Old 04-15-2007 | 06:04 PM
throttleup's Avatar
We need a little more data:
What is your gear ratio?
What is the WOT RPM with each of the props?
What is the MPH with each of the props via gps?
With a little data we can take a look for you.
Julie
throttleup is offline
Old 04-15-2007 | 08:59 PM
All the props reach 5000 rpm's that's the max. the boat is 4900 lb's its 26.5 feet long. The top speed with all props is 68 gps even at 5000 rpm's
Old 04-16-2007 | 02:34 PM
Pat McPherson's Avatar
68mph at 5000rpm sounds about right spinning a 25pM+ or 26pB1 on your boat.
If you are still able to pull 5000rpm with a 27pM+ then you should be going faster than with a 25p.
What size engine?
454s normally make 500HP at about 5600rpm and 502s around 5200rpm.
Patrick
Pat McPherson is offline
Old 04-16-2007 | 11:44 PM
The engine is a 565 ci. I was expecting 75-80 on this hull.
Old 04-16-2007 | 11:45 PM
[QUOTE=perform330;2096127]The engine is a 565 ci. I was expecting 75-80 on this hull.
Old 04-17-2007 | 02:18 AM
Post the dyno numbers for hp and torque from 3500-6000rpms.
Griff is offline
