RPM after labbing? >
RPM after labbing?
RPM after labbing?
Old 04-15-2007 | 02:31 PM
Default RPM after labbing?
If you've got a prop that lets the boat top out at the right RPM, what will happen after it's labed? Let's say you gain 2mph, will that new top speed occur at a higher RPM, or does it just reduce slip, thereby maintaining the RPM at a high speed?
bcarpman is offline
Old 04-15-2007 | 04:50 PM
Depends on what is done to the prop. If its a standard lab, it will pick up rpms as well as speed in most cases.
You can add cupping, change rake and increase pitch to reduce the rpm increase.
Griff is offline
masher44
Prop Talk
2
10-03-2007 05:41 PM
Rebel_Heart
Prop Talk
9
07-06-2007 09:27 AM
1BIGJIM
5
07-04-2006 12:50 PM
Pat McPherson
Prop Talk
21
12-12-2005 11:50 AM
imongo
10
06-11-2002 04:43 PM
