-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   need prop advise, 42 fountain (https://www.offshoreonly.com/forums/prop-talk/159394-need-prop-advise-42-fountain.html)
eeasy 05-31-2007 07:58 AM
Do you think I need the labbed props if I am not looking for additional top end? Thanks
bbladesprops 05-31-2007 10:29 AM
You can most definately go non Labbed.
The Maximus propellers respond very well to Labbing and can allow you to step up 2 inches higher in pitch. This will increase the cruising speeds too. The props also have large diameters which can affect boat attitude. Therefore adjusting this may help overall performance.
Defnately try stock props frst. We do ave these fortesting and can ship them to you.
Brett
TxHawk 05-31-2007 11:43 AM
I set a couple 42's with Staggered 525s and gensets. We found that a 30P5X and 1 " spacer got the best all around performance and got a top speed of 83mph. You may also have a professional look at the bottom. I had one 42' pick up 4 mph when removing a hook.
Single With Twins 05-31-2007 12:20 PM
I have a 1999 42 with 600's and XR's..........first tried 4 blad labbed Bravo 33's, worked pretty good, no problem out of the hole and good mid range...........put on the the 5 blade Hydromotive 29's...WOW, big difference, about the same out of the hole but mid-range picked up and topped out at 5300 WOT. Perfect for me......about 3500RPM and 51 mph......over half a tank of fuel and four people on board at 5000rpm.....84.6 on handheld gps.
Hope that helps....................good luck
shark42 05-31-2007 06:37 PM
were those p5's or p5x's? I have a 2000 42 with 500's and have tried 25p5x's and hit the rev limiters, so they are sending me some 26's to try this weekend. They said the p5x gives more bow lift than the p5.
eeasy 05-31-2007 07:01 PM
Since I have 32 pitch now, should I step down to 29 of 30? It sounds like I need to try some Maximus 30p or Hydromotive 29p5. Will probably try the non-labbed route first and see what I get. Has anyone tried both the Maximus and Hydromotive and had a preference for my set-up?
Single With Twins 06-01-2007 07:41 AM
SHARK42.................they are p5x i was told not to try the p5..............not sure the reason, just trust Raymond Roberts and Randy Sweers advise with set-up so never question them. :drink:
BZ 06-01-2007 08:36 AM
Originally Posted by bbladesprops (Post 2145760)
I agree with Labbed Maximus propellers to the specific recipe your applications needs to suit your low and mid range goals.
We do a pair custom to your set up for for $2860 plus shipping.
Hi Brett, I just left you a message I need to tt you about props to have b/4 I leave for the LOTO on Wednesday (Frankie And Louies Poker Run) please call me. I left you the numbers......BZ
BZ 06-01-2007 08:38 AM
I am trying to get a set from bblades will you be around for the poker run nex week-end at loto???? June 9th poss some prop testing on friday????? BZ
eeasy 06-01-2007 09:25 AM
I think the earliest I can get to the lake for any testing will be Friday, June 15th. If you happen to get a set that I can test the next weekend, let me know and I can get them back to you that Saturday or Sunday or send them back on Monday.
