Need prop help with Sea-Ray ( sorry )
OK,
You have 3 blade propellers and most likely Bravo drives. Depending on the rpm you can currently run at wide open throttle, I highly recomend Revolution 4 propellers. You cam more than likely go down to 19 pitch props and inprove your performance across the board. These propellers will make boating more enjoyable and less stressfull. Like it is supposed to be! There may be other options also.
If you can, post more information on the rpm and speed capabilities you are seeing and we can discuss the options after looking at your data.
[email protected]
[email protected]
Hey brett ... i was unable to get the readings as discussed due to choppy conditions ... If my memoery serves me right ... the boat max RPM's around 5000 - 5200 and the speed is in the mid 50's ... i hope this is close enough info to get some direction.
We should talk when we have the chance.
Brett
Brett
[email protected]
[email protected]
tomtbone1993
10-24-2005 11:49 PM
