Going from 1:50 to 1:30 ?? >
Old 07-20-2007 | 06:38 AM
Canada Jeff's Avatar
Default Going from 1:50 to 1:30 ??
if I'm turning a Labed 30 Bravo one, with a 1:50 Bravo drive, and I go to a B Max 1:30 ratio, what prop would I need? Educated guess please?
Canada Jeff is offline
Old 07-20-2007 | 07:13 AM
AKA NoMoBoatin
Had the bmaxs and went down from a 32 stock 4 blade to a 28 stock 4 blade but needed to try a 26 or labbed 28s.
docmanrich37 is offline
Old 07-20-2007 | 09:09 AM
throttleup's Avatar
About a 10% reduction in pitch.
Julie
throttleup is offline
Old 07-20-2007 | 09:19 AM
tssteph's Avatar
30 pitch with 1.50 ratio is the same as a 26 pitch with 1.30 ratio, mathmatically anyway.
http://www.go-fast.com/Prop_Slip_Calculator.htm
tssteph is offline
Old 07-20-2007 | 09:25 PM
I recently went from a 1.50 to a 1.36.
Had a 28 bravo and now a labbed 26 bravo.
raytart is offline
Old 07-21-2007 | 11:15 AM
I went from a lab finished 30 to a labbed 26 the math is correct
RBeyer is offline
Old 07-23-2007 | 09:29 AM
Thanx all. I will be sticking with another XR drive instead of B max this time.
Old 08-09-2007 | 05:46 PM
Strip Poker 388's Avatar
Rob
Mine came with 30 and 1.50,went to bmaxs, had to run 24's to get the rpm back.
I put Whipples on and when up 6 prop sizes, 24 to 30's and went up from 5200 to 6000rpm,18-20 mph gain
Strip Poker 388 is offline
