What is the best prop for a 31' scarb with twin 502's >
Old 09-17-2007 | 11:17 AM
Default What is the best prop for a 31' scarb with twin 502's
The stoce props that were three blade, round ear, 26" pitch were cavitating at start up
scandelous is offline
Old 09-17-2007 | 01:21 PM
throttleup's Avatar
What year is your hull?
What drives and gear ratio?
Julie
throttleup is offline
Old 09-17-2007 | 02:00 PM
The hull is a 1996
Bravo 1 out drive
I'm not sure of the ratio
Old 09-17-2007 | 02:10 PM
throttleup's Avatar
You need to run a Bravo I propeller on that hull, unless you have really heavy engines.
Julie
Old 09-17-2007 | 02:44 PM
last weekend a tried a 24 pitch, four blade Hydromnotive, it seamed to have a good hole shot. I could not tell what my top end was doing there were 4-5 footer out there during testing, so I spent most of my time airborne.
Old 09-17-2007 | 05:13 PM
throttleup's Avatar
Try it again in better water, for testing. This will give you a feel for the stern lift of a semi-cleaver propeller.
Julie
Old 09-17-2007 | 06:29 PM
will do ...
Thank you
Old 09-17-2007 | 07:45 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
I agree with Julie that the Bravo 1 propellers in stock form are a great starting point. They will give you great all around performance on your vintage hull.
[email protected]
bbladesprops is offline
Old 09-18-2007 | 06:53 AM
The trubble was that the stock props cavitated during accelleration.
Old 09-18-2007 | 07:52 AM
throttleup's Avatar
Which props are you refering too?
Julie
