Wheel advice for 38' Lightning w/staggered 525 efi's >
Old 04-13-2008 | 03:02 PM
Default Wheel advice for 38' Lightning w/staggered 525 efi's
Last new I bought a left over 06. I have attached the test report from Fountain. The performance numbers are very close to what I got. With two people and 30 - 40 gallons of gas my WOT (5300 - 5350) was 95.5 on a fresh water lake. The boat came with Bravo 1 4 Blade's 32P 48-831920. I bought a set of Hydromotive 15 x 30 P5-X 5 Blade's HCCL30*P5-X. I picked up 1.5 mph to 87. I am not apposed to changing wheel's or tweaking one of the sets I have. Let me know if you think I can do better. Thanks!!
File Type: pdf
KS_Jayhawk is offline
Old 04-13-2008 | 08:32 PM
HiPerf2000's Avatar
these may work for your setup....
http://www.offshoreonlyclassifieds.c...o20571-en.html
HiPerf2000 is offline
Old 04-13-2008 | 10:25 PM
Are these yours?
Old 04-14-2008 | 07:33 AM
HiPerf2000's Avatar
yes. They are designed for stepped hulls with high X dimensions. Thats why I chimmed in when I saw your setup.
Old 04-14-2008 | 11:15 AM
They sound nice. When I get a chance I am going to call Hyromotive and get their recommendation.
Old 04-18-2008 | 11:57 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Are you saying you picked up 1.5 mph till you got to 87?
What happened after that?
34 Labbed B1's for top speed since you ran 10% slip with the 32's.
[email protected]
bbladesprops is offline
Old 04-18-2008 | 12:01 PM
Hi Brett: We talked on the phone a few days ago about this. I have misplaced my notes from the last speed test I did. In two weeks I am going to run speed tests with the B1 and Hydro P5. I will make notes on rpm so you can verify slip. I will be in touch. Rodney
convincor253
Fountain
56
09-07-2023 03:48 PM
jmackin
Fountain
12
10-03-2008 03:56 PM
convincor253
Fountain
7
11-21-2006 01:03 AM
BamBam
03-20-2006 10:28 AM
hot water
Fountain
10
07-05-2003 07:47 PM
