alpha drives and Bravo Props >
Old 04-18-2008 | 08:20 PM
Default alpha drives and Bravo Props
i have 3 bl, Mirage Plus 21p props, do they fit on alpha drives,
thanks
AM
amarek is offline
Old 04-19-2008 | 01:06 AM
yes....thats the props I run on my alpha set up.......you'll probably have to change the anode to the type without the little fin though.....doug
pullmytrigger is offline
Old 04-19-2008 | 07:39 AM
Correct. If you have a regular Alpha with a standard fin tab anode you will need to replace it with a flat plate anode or a Merc HP tap anode. It still has a fin but more streamlined and will clear larger props.
Ryan00TJ is offline
85Baja
15
08-25-2008 10:31 PM
Rebel_Heart
Prop Talk
2
05-22-2007 08:59 PM
JJONES
Prop Talk
4
04-13-2006 01:41 PM
PorscheSpeed
1
03-14-2004 10:30 AM
Hot Boat
7
01-09-2002 01:16 AM
