Prop Shaft Adapter >
Prop Shaft Adapter
Prop Shaft Adapter
Old 05-16-2008 | 12:04 PM
Charter Member # 1083
Default Prop Shaft Adapter
Does anyone know if Merc makes a prop shaft adapter that will adapt a std Bravo 1 collor to an XR bigger shaft using the same prop that was on the Bravo 1? In other words I want to use a set of props from an XR drive on a std Bravo 1.
Thanks,
Bob
If it's not a thunder run.............than you're just burnen fuel!!!
BOB ONEIL is offline
Old 05-16-2008 | 05:08 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Yes there are different inserts. Depending on the vintage and make of your props, you'll be good to go with the correct insert.
Give us a call and we can dicuss the options.
[email protected]
bbladesprops is offline
Cord
2
07-23-2004 10:30 AM
jmont34
1
07-19-2004 04:16 PM
Andy
3
05-25-2003 10:03 PM
MIKEHTMSR24
07-22-2002 03:18 PM
MIKEHTMSR24
0
07-22-2002 01:40 PM
