Mirage plus  washers ? >
Old 05-29-2008 | 09:32 AM
offthefront's Avatar
Default Mirage plus washers ?
Trying to test some 27 M+ (solid hubs) on Bravo Drives and we got the washer setup the book calls for ..
Thrust washer ... then a splined washer and a flat washer under the nut ....with everything torqued there is still about 1/8" movement forward and aft with the prop ....It doesnt look right to me but the shop I got the info from does not deal with HP stuff too often .... they are saying under load the prop is pushing against the Thrust washer so it should not matter ... I just dont like the idea of the prop being bale to move on the shaft .....m
offthefront is offline
Old 05-29-2008 | 07:59 PM
rchevelle71's Avatar
Are ya sure the play is not in the propshaft??
rchevelle71 is offline
Old 05-29-2008 | 08:20 PM
yup ... I shimmed it today with 1/8" washer.....tightened up pretty good .... we'll see ....m
Old 05-29-2008 | 08:25 PM
OK, just checking
Old 05-30-2008 | 12:55 AM
There should be NO PLAY!!!!!!!!! call BBlades to get the right parts. I think there are 2 different ones with different washers.
Griff is offline
Old 05-30-2008 | 04:30 AM
After shimming it .... it seems ok but your right I will check with B ......m
ctadams21
7
04-01-2007 01:11 PM
BAD-HABIT
04-11-2005 09:30 AM
Mr Gadgets
10
06-06-2004 12:26 PM
impulsive
01-15-2004 12:18 PM
