-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   2004 22 velocity, 300x prop and set up? (https://www.offshoreonly.com/forums/prop-talk/190493-2004-22-velocity-300x-prop-set-up.html)
Buford T. Justice 07-08-2008 03:33 PM
looking for any advice on prop choice and set up on jack plate THANKS!
cowisl 07-09-2008 11:58 AM
for all around i would get a lab finished bravo 1 4blade with vent holes. contact brett at bblades.
bbladesprops 07-11-2008 11:04 AM
Believe it or not we used to run Trophy small hub props on those boats with 3 litre motors.
But now cowil is right. 14.75" diameter cupped Bravo 1 props with vent holes are the ticket.
Buford T. Justice 07-16-2008 01:07 AM
I'm running a 24 pitch bravo right now thats been labbed by a local company (probably not the best job) and can only get about 6200 rpm's. The limiter is at 6800, so do i drop to a 22 pitch or would it be worth it to swap the 1:62 ratio lower unit for a 1:75. any major speed gains?
