Props for 25' Powerplay >
Old 12-13-2008 | 02:44 PM
Default Props for 25' Powerplay
I'm running a pair of 225 Pro Max's with stock 26" Bravo 1's turning out. I know there is more speed potential.
Was going to swap lowers and turn props in this spring to see if there is any difference.
I need a four blade as the motors are mounted high and I'm in the ocean a lot.
I can pull these current props pretty close to redline (6800).
Brett, any experience with this hull? Suggestions?
Powerplay25 is offline
Old 12-13-2008 | 04:07 PM
northernoffshore's Avatar
Don't like choppers 28"pitch?
northernoffshore is offline
Old 12-13-2008 | 08:02 PM
i have 28 with 4 blade bravo I's by bblades. Brett nailed the prop setup
cowisl is offline
Old 12-13-2008 | 11:14 PM
Is that what you are running? I feel a 3 blade will break loose too much because of the engine height.
Old 12-14-2008 | 09:32 AM
28" lab props merc choppers , I have a new set from dah prop from wisc. for spares. The motors are even or above the bottom . Shoots up on plane. I also have a set of 28 bravo 1 that are a little big for the boat.
Old 12-16-2008 | 01:01 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
I like the Lab 28 Bravo props. I would also try the inward rotation. Call us anytime and we can discuss the options. We also have test 28 Bravo 1's if you are interested.
Brett
[email protected]
bbladesprops is offline
Powerplay25
11-02-2008 02:22 PM
charliefun1
09-26-2006 05:05 AM
kevinbirrell
Prop Talk
0
06-27-2006 07:24 PM
dockrocker
08-22-2005 04:33 PM
KN
Powerplay
2
06-05-2005 09:32 PM
