Worried
1 Attachment(s)
I want to put this out to all you prop guru's:
I am now worried about the durability of my IMCO SC drive. I have an 09 Nordic Heat with a 600sci that I have been doing prop and spacer testing for the last 6 months. Below is the table of my results. These are real slip numbers. Tach has been verified with a digital tach, and speeds with my analog GPS, my digital GPS and a radar gun. The current best prop is a Hering 26 pitch, 5 blade bravo style prop. Slip is coming in at 5.2% I am not the first Nordic Heat to post such low slip numbers. The Illmore 700 Heat regularly posts numbers between 6%-8% with the same drive and hull. For you doubters: Prop= 26 pitch Hering 5 blade bravo style prop Speed= 83.8 mph RPM= 5400rpm -- On the rev limiter I am about to upgrade my 600hp motor to aproximately 750+hp using some upgrades offered by Whipple for my motor. What I am worried about is that 750+hp and 5.2% slip on a 28 foot boat, sounds like a recipe for a broken drive. What do you think?? Should I switch back to a 4 blade prop for reliability sake? How much horsepower is safe in front of the IMCO SC drive? I would like to hear some opinions. Chris |
| All times are GMT -5. The time now is 02:31 AM. |
