Prop size vs RPM - speed??? >
Old 03-27-2009 | 09:00 PM
Default Prop size vs RPM - speed???
With a twin application if you ran 27 pitch mirages @ 5200 RPM = What speed??? Approx.
(32' light layup 6500 pds) flat/chop water.
John
getrdunn is offline
Old 03-28-2009 | 02:06 AM
That would depend on the drive ratio and approximate prop slip %
http://go-fast.com/Prop_Slip_Calculator.htm
Griff is offline
Old 03-30-2009 | 05:56 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
12% slip gives you 78 mph.
B
[email protected]
bbladesprops is offline
Old 03-30-2009 | 08:11 PM
John
What ratio ????
DareDevil is offline
Old 03-31-2009 | 08:07 PM
Default ratio
Originally Posted by daredevil
What ratio ????
I realized I forgot to mention the ratio with the first thread and then I figured it out from the website mentioned. I use to be so good at this when I was running a lot more. I could always tell when somebody was full of s**t when they said how fast they were going when I knew what props/rpm/'s they were at.
anyhow I am pretty certain the merc. trans / trs set up is 1.5??? the boat was running 23's with stock 330's at 4600 rpm at near or around 62 - 64 mph.
I not real familiar with the trs drives and trans. I've always had bravos in the past.
any help with the said set up..
getrdunn is offline
Old 04-01-2009 | 09:39 AM
Smile
That would be under 6%. Probably too good to be true.
Speedo or GPS?
[email protected]
Old 04-01-2009 | 08:03 PM
Default to good to be true
Speedo or GPS?
speedo, sorry about that and not gafrig either.
is there a common ratio for the old trs drive and merc trans. this is a 1978 boat.
getrdunn is offline
Old 04-01-2009 | 09:05 PM
Usualy they are 1.5 ratio and the tranny is neutral (1:1) your real speed was more likeley around 56 MPH !!!!
Old 04-01-2009 | 09:06 PM
John
Also a light layup ??? would be my AERO-TEK ,,, 32 feet single BB speedmaster with Tranny and 100 gallons of fuel = 5800 pounds .LOL
Old 04-03-2009 | 09:49 AM
Need a single screw I guess.
getrdunn is offline
SKATERKAT
Classic Offshore
37
02-10-2012 07:09 PM
Back4More
10-14-2006 08:36 AM
hp500efi
21
09-18-2006 10:40 AM
mleslie951
Apache
1
05-05-2002 09:31 AM
Ghia
4
03-18-2002 12:06 AM
