Prop Question >
Prop Question
Prop Question
Old 04-10-2009 | 09:10 AM
Default Prop Question
I have a 86 Cig and that I bought last summer. Well at the end of the year the marina took off the props with out labeling which one is which
Can anyone tell me the best way to get them back on the correct way.
rockstar38 is offline
Old 04-10-2009 | 10:00 AM
I'll take a guess...... What drives do you have? Most older Cigs with TRS drives turn outward (right hand prop on Starboard side). I would start here and shift into gear momentarily on the trailer and verify the rotation is correct.
CignificantOther is offline
Old 04-10-2009 | 12:18 PM
Rookie's Avatar
Side note: If you do have TRS drives and you do put the props on and the boat is goes in reverse when forward and vice versa. DO NOT try to get on plane with the trannies in reverse it will wipe out the tranny in no time. Unlike a Bravo boat this can not be done.
Rookie is offline
Old 04-10-2009 | 01:48 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Most likely outward rotation. Run the boat on the trailer without the props and put into forward. This will tell the correct propeller to install on the correct drive.
Brett
[email protected]
bbladesprops is offline
